- Potentiometer to control 'day' and 'night' light threshold instead of using hard coded value.
- Potentiometer to control Temp and Humidity thresholds instead of using hard coded values.
A project log for Humidity/Temp Controlled Power Outlet
A standard USA 110v power outlet which is connected to an arduino via a relay and activated based on certain temperature and humidity ranges
