First code
A project log for SHTTTRRR
A small shutter controller for Canon EOS Cameras
glitchmakerGlitchmaker 01/11/2015 at 20:170 Comments
As a first approach i wanted to find out how to count the time between two button presses. Based on this project I would use a one second watchdog timer in interrupt mode to increment a counter:
ISR(WDT_vect)
	seconds++;
Instead of the buttons being pooled, I also implemented a hardware pin interrupt. When the interrupt occours, the ISR function is called with the PCINT0 vector, as this:
ISR(PCINT0_vect)
	unset_interrupt();
	switch(button_press)
		case START_P:
		start_second = get_seconds();
		blink(3);
		break;
		case STOP_P:
		stop_second = get_seconds();
		blink(2);
		break;
		default:
		break;
	button_press++;
	duration = stop_second - start_second;
	if(button_press>=3){
		for (i=0; i <duration; i++)
			blink(1);
		button_press = START_P;
	set_interrupt();
The unset_interrupt() function stops the hardware interrupt, eliminating interference, and after running the code, we use set_interrupt() to re-enable the hardware interrupt.
The function get_second() gets the current second, using atomic operation, from the seconds variable.
int get_seconds()
	int current_second;
	ATOMIC_BLOCK(ATOMIC_FORCEON){
		current_second = seconds;
	return current_second;
The next step I want to take is to eliminate the _delay_ms() functions of my code, do a little clean up and advance with the shutter part.
