head mounting
A project log for R8-D8 - a distant relative of R2-D2
a 12cm radius, 3d printed R2-D2 with some motors, servos and blinky stuff that follows lines, persons or just drives around via bluetooth
davedarkodavedarko 01/11/2015 at 17:240 Comments
As almost expected but neglected while drawing in 123D Design - the 12cm bowl isn't actually a 12cm bowl but bigger and I have to find a way to fix the bowl to the upper part of my bearing. I was able to find some cheap 5mm balls on eBay for about 3 euros and also ordered a metal servo to replace the hard working SG90 plastic servo.
