Part 4: Calibrating the thermistor
A project log for Thermostat for 3D Printer extruder head
Rather than spend coin to replace my CNC's TinyG board, I decided to use stuff I had lying around to control the extruder temperature
brendan-robertBrendan Robert 01/20/2015 at 18:140 Comments
This is the part that is currently underway -- Since I don't know what thermistor was used I don't have a data sheet that tells me its resistance at a known temperature (25C) or its beta value. If you use an extruder head with a known part number for the thermistor you will not have to do this part...
