Project scrapped
A project log for R.Cerda - a simple and cheap Raspberry Pi robot
How to build easily and at low cost a robot based on a raspberry pi
audrey-robinelAudrey Robinel 04/09/2018 at 04:400 Comments
Hello everyone!
This is not an update for this robot, but rather a closure log.
Indeed, this project was scrapped a long time ago, and i progressed a lot, so that i don't see this robot worthy of anything but simply learning.
It was neither very precise, nor well built. It was my first complete raspberry pi robot, and i liked it but it was flawed. If you are starting in robotics, you can probably learn a thing or two there, but still, i have more interesting robots to show as of now :
The first one is more complex, but superior in many aspects to the second one. However, R.Ian is simpler, and way cheaper, but less capable than R.Hasika.
Still, both robots share A LOT, and they may later on converge.
Unlike R.Cerda, both are active projects (although they don't see a lot of updates now, because i work on other projects very actively these days; however this work will eventually transfer to these robots, and huge progress will come to those robots), and you have no reasons to build a R.Cerda instead of a R.Ian or a R.Hasika.
So, see you there :)
