code changes
A project log for Web based solar panel monitoring/managment
Arduino enable web server to monitor a small solar array and power management systems.
garyGary 05/02/2014 at 00:480 Comments
I changed the straight line voltage  get code into a function so I can call it will multiple an analog pin number as a variable. Next is to do  turn the current gathering code into a function. This also offers flexibility to have some other chipset get the current and voltage and and all I need to do is fix the called code.
Calling code.
float voltage=get_voltage(A5); /get volatge on A5
Called code.
float get_voltage ( int vpin ) {
float gvolt=(analogRead(vpin)/4.092)/10;
return gvolt;
