acs715 sketch
A project log for Web based solar panel monitoring/managment
Arduino enable web server to monitor a small solar array and power management systems.
garyGary 03/19/2014 at 00:420 Comments
Here is a sketch to read the acs715 module and print the current going through the module. NOTE: the module is directional in nature. If your getting odd readings flip the connections on the acs715 module. I am not trying to lab grade current measurements, just get a  reasonable look at current being used.  If you need more  accurate reading you might consider looping through the current read several times and averaging your results.
Read http://www.pololu.com/ acs715 30amp 30v current modules
and serial print the value.
Gary (N8EMR)
ohgary@gmail.com
float current_input_pin = A4;            // Analog input pin that the carrier board OUT is connected to
float current_input_value = 0;          // value read from the carrier boar
float amps = 0;
void setup() {
Serial.begin(9600); // initialize serial communications for debugging.
void loop() {
current_input_value = analogRead(current_input_pin);
amps = float ((((long)current_input_value * 5000 / 1024) - 500 ) * 1000 / 133)/1000;
if (amps < 0 )
amps = 0 ; // Get rid of sensor noise when current is at/near zero.
Serial.print(amps);
Serial.print("A ");
Serial.println("");
delay(1000);
