Mystery Box
A reverse geocache puzzle box incorporating a sci-fi storyline and local history.
To open the box, the player will need to solve various puzzles around town, visiting some interesting and unknown spots along the way.
This project pulls from the work of a few other amazing artists and makers:
Captain Hermano's Mystery Box by Raffi
Password Protected Sketchbook by Durss
Bareduino by Joseph Dattilo
There are many unnamed others who have helped and influenced this project as I've scoured the web for help solving problems or learning how to bend the atmega328 to my will.
  • 1 × Bareduino made from scratch arduino board using the atmega328p-pu
  • 1 × Box I found mine at TJ Maxx Home goods. World market might also have good choices.
  • 1 × 20x4 Sainsmart i2c LCD i2c is cool
  • 1 × ublox neo 6mv2 GPS module
  • Setup
    stopsendingmejunk01/24/2015 at 02:10 0 comments
    To get an idea of what the box would look like and what its capabilities would be, I first found a box of reasonable size. I found a great one with an old world map on the outside along with leather straps for the closure. This was found at TJ Maxx Homegoods, which is a great place to find such a thing. Another option would be World Market, but I was satisfied with the box from Home Goods.
    Next I gathered the main components - LCD screen, keypad, switch and locking switch, Atmega328p-pu, etc. I put together a bareduino to use as the main brain.
    Next up I measured everything out and put together a design in inkscape for the laser cutter. I cut a cardboard prototype at the wonderful Make Salt Lake makerspace and after some adjustments cut a version out of 1/5" birch veneer plywood.
    Originally I wanted to make the door an iris that automatically opened, but deciding that was too difficult I added a second puzzle to the upper lid of the box. The design was taken from this instructable with some changes to fit the theme of my box. One circle is now an analog clock and another circle contains characters from the Deseret Alphabet, which ties into the local history where the box will be played.
    After staining everything and getting it set into the box I set to work on the programming portion. So far I have the GPS and LCD up and running. There is more work to do on the GPS implementation and then I will begin programming the steps of the game.
View project log
