Everything setup except for correct voltage output of sync lines
A project log for N64 PAL RGB DAC board
A small but useful board that will spark new life in my old yet still wonderful N64
michele-perlaMichele Perla 04/07/2015 at 12:360 Comments
The layout of the board is finished, I can't upload it right now because I got that on a different PC. The only thing I'm missing (which is also missing from the original schematic) is correcting the output voltage of the sync lines to a proper TV-acceptable signal. Any suggestion? I'm posting this on the stack as well.
