Carbide Bicycle Lamp LED Retrofit
I retrofit an old Luminor Carbide Bicycle Lamp using LEDs in order for it to be used on an e-bike.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This is a Luminor Carbide Bicycle Lamp from probably the early 1920s. I’m retrofitting it so that it can run off of 12V DC power as used on an electric bicycle.
I took it apart to clean out the old carbide and prepare it for desoldering. I ran cables throughout the various parts and added a 3 position switch for On / Off and intensity level.
I mounted an LED to a heat sink and then connected it to the wiring.
