Now that the Project has successfully ripened, it is time to make some progress!
So I made a simple frame from wood (2.5cm x 9cm):
![](https://cdn.hackaday.io/images/7023721584278917619.jpg)
The frame is just glued using simple tongue and groove joints:
![](https://cdn.hackaday.io/images/3537611584279496779.jpg)
The grooves were cut with a router, and the tongues were cut with a band-saw. Then I just glued a 3mm three-layer-board on top.
Next I assembled all the parts that gathered dust for the last years:
![](https://cdn.hackaday.io/images/3509641584279004133.jpg)
The frame is 2m x 1m, which I realize now is a bit over the top, but you've got to give your megalomania a treat sometimes I guess.
Right now I'm working on the software and I probably there will be more updates in the next weeks.
