Prototype (stripboard) done
A project log for Polling a Push Button Rotary Encoder
A push button rotary encoder is a neat input device for an Arduino. Unfortunately interfacing to it is not!
agpcooperagp.cooper 01/29/2018 at 14:590 Comments
Second stripboad prototype done
I spent a lot of time getting this done.
Here is the first prototype that got the LCD display working:
And the final prototype design:
Here is the assembled strip-board without the modules installed:
And with the LCD and RTC running (it is checking my custom clock):
Next step
Next is to get the menu system integrated.
Front panel
Now that the components have been located I can design the front panel.
Finally
The idea is that once I have a fully worked out prototype (complete with housing and power supply), I will get some PCBs made so I can reuse the design for other projects.
Magic
