Casing [Designs and materials]
A project log for Portable Raspberry Pi gaming handheld
Made from a Raspberry Pi 2 B, a 4,3" TFT screen, a powerbank and a modified SNES controller.
lumorLumor • 12/08/2015 at 10:37•0 Comments
I spend the last one or two months carefully designing the case and i'm finally confident enough about it to make it a reality. I ordered the PVC and Polycarbonate plates from an online webshop and they arived within 2 days. As you can see i ordered 5 of everything for when i screw something up (it's gonna happen).
In my previous post i mentioned i'd be making the case out of polyethylene plastic, however polyethylene turns out to be really hard to glue so i used PVC instead.
Here's a peek at the designs and the materials, i'll share more details later :
Structure plate, all the electronics are mounted on here.
Bottom plate :
Bottom plate and structure plate mounted together :
