Materials for the first try
A project log for Carbon/silicone hotplate
Because simply screwing or soldering resistors to a plate is boring.
christophChristoph 02/13/2015 at 14:260 Comments
So far I've got these leftovers:
All of the above can handle temperatures of at least 300 °C (limited by the silicone). Aramid will loose its strength at high temperatures, but the design will not rely on that parameter. The first things to do now:
