Pressure sensor output
A project log for basePnP - pick and place machine
Pick and place machines seems to be popular in these days. So why not to build one?
hynaHyna 04/14/2015 at 23:580 Comments
Seems that detecting parts on the nozzle will be quite easy.
First section of the graph is with closed vacuum valve - sensor is on atmosphere pressure. Then valve is opened (no device attached to the nozzle )and ADC value goes quickly down to 3300. After device is suctioned to the nozzle, there is another drop down to 2900.
This test was performed with 0.9mm nozzle. So for smaller nozzle diameter (for placing 0402 packages) difference in pressure will be much smaller, but still be detectable.
