This sucks, I got a better idea.
A project log for Arcus-3D-P1 - Pick and Place for 3D printers
Open source, mostly 3D printable, lightweight pick and place head for a standard groove mount
daren-schwenkeDaren Schwenke 08/08/2018 at 00:240 Comments
After two days of avoiding gluing the other 6 stilts I would need on the board, I had a better idea.
I'm going to move the steppers to the bottom of the board instead, and pass the drive 'cables' up through holes.
The feeders, frame, and PCB mounts can just get mounted to the top of the board then, and everything else like the majority of the support electronics and wiring can all be on the bottom.  Much cleaner look too.
Better plan.  Doing it.
