Looking good..
A project log for Arcus-3D-P1 - Pick and Place for 3D printers
Open source, mostly 3D printable, lightweight pick and place head for a standard groove mount
daren-schwenkeDaren Schwenke 02/09/2018 at 20:030 Comments
Changed my optical representation from a cone to 4:3 to match the camera and this yielded some better dimensions I could work with.
The path for the swingarm works, but I have not generated the actual part yet.
Did a little more cleanup, and it's finally ready to print.
It's only 55mm tall, but there are some bridges required which means I should probably take it easy on the print speed.  I also have to dry out my nylon filament first as it's been a while since it's been used.
