Experimental dekatron cell get two more tube plates
A project log for DekatronPC
Silicon-free computer on vacuum and cold-cathode tubes with pure brainfuck instruction set
artem-kashkanovArtem Kashkanov 04/10/2022 at 08:270 Comments
I made two more tube plates for experimental dekatron cell.
From left to right
Now, 3U crate look like this. But I need to re-drill the rail holes to give the modules more space between each other. On the back, coolers, transformers and rectifiers would be added.
