Example
A project log for Tonerless PCB Templates for UV Exposure
A method for creating long life reusable templates for UV exposing PC Boards
flcfl@C@ 04/11/2015 at 08:100 Comments
So, this probably should be posted in the other project since this is a positive, not a negative for the glass...but I was testing the parameters... this is on glass, but it's a positive image cut... I just wanted to illustrate the traces...
These are near perfection...
If you did this on copper instead of the glass like I did here.. this would come out very nice... I'm going to go ahead and try this on copper tomorrow and post it on the other project ( https://hackaday.io/project/3904-tonerless-pcb-etch-resist-direct-to-pcb-method )...
Getting very close now....
Just need to get chilipeppr to allow layer selection, allow reversing the layer image, and toggle M3 and M5 instead of moving the Z axis...and it'd be awesome...
Anyone wanted to help me fork chilipeppr.com's eagle .brd import to do these things...I'll do just about anything.. =)
