Breadboard!
A project log for +/- 10V to 0-3.3V Translator
Differential Op-Amp Circuit to translate +/-10V DAC signals from test equipment to 0-3.3V for Teensy 3.6 Board
emach00Emach00 03/14/2018 at 18:050 Comments
Built A breadboard version of the circuit. Checked out the linear supply and the switched capacitor supply. Haven't had a chance yet to try the op-amp section. Eventually plan to move everything to protoboard and a project box if the breadboard version pans out.
