TTA - Transfer-Triggered Architectures
A project log for PDP - Processor Design Principles
Distilling my experience and wisdom about the architecture, organisation and design choices of my CPUs
yann-guidon-ygdesYann Guidon / YGDES 02/25/2018 at 12:100 Comments
We can find some TTA processors on Hackaday.io, such as #TD4 CPU so the idea has a low barrier of entry. It was also once considered for the early F-CPU project. Some commercial processors, such a Maxim's MAXQ, exist.
One advantage I see is : along with a VLIW approach, it could potentially handle OOO inherently, with low overhead. However, code density might not be good enough and people are not used to TTA idioms so on-the-fly binary translation from more classic RISC instructions sounds like a nice compromise. However this raises the complexity and increases latency, for an unknown gain in ILP, so a simple RISC (even superscalar) would work better in the beginning.
I also think that the system presented in https://web.archive.org/web/20071013182106/http://byte.com/art/9502/sec13/art1.htm is pretty under-efficient... I object that the very large crossbar bus that adds significant load (and surface), slowing down the whole (been there with FC0). There is also some redundancy, in even a simple case where you want to perform an addition : the 3 instructions contain the meaning of addition 3 times, in the 3 addresses of the source and destination registers. OTA mentions addition only once in the opcode...
TTA makes sense in a VLIW system, with some clever partitioning (to reduce bus complexity and fanout/fanin), which is already inherent in OTA architectures. This is why YASEP and YGREC are somehow a mix of OTA (for basic operations) and TTA (for memory and instruction control), they use the best approach for each case where it makes sense.
Oh, and how do you handle faults, context swaps, and register backup/restore in general ?
