Characterizing the VW ECU
A project log for ECUality1
A light, open-source Engine Control Unit (ECU) using Arduino
Mike ThielvoldtMike Thielvoldt 03/11/2015 at 13:431 Comment
Goals:
Here, I use an Arduino Leonardo to send signals to the original ECU that simulate sensor data from a running engine. With that stimulus going in, I record the pulse-duration of the injector signal coming out.
The breadboard between the Leonardo and the ECU contains:
Mike Thielvoldt wrote 03/20/2015 at 08:04 point
An engine fuel-map:
This was obtained at an O2 input of .5V, which I found to cause the injector duration to remain constant.   The air variable represents the 8-bit pwm value that was used to simulate the 0 - 5V signal produced by the air flow sensor.  255 would correspond to 5V.  0 to 0V.  Linear in between.
The left column is the air variable,
The top column is the RPM variable.
the block of data in between is us/4 of injector duration.  (to get microseconds, multiply these numbers by 4).
RPM:        500    695    965    1341    1863    2589    3589    5000
 air:  220    2470    2470    2472    2464    2471    2464    2459    1917
 air:  180    2162    2170    2160    2160    2333    2021    1597    1204
 air:  140    1900    1898    1918    1896    1632    1236    943    765
 air:  100    1789    1750    1618    1228    948    755    616    596
 air:  80    1518    1498    1177    941    749    622    588    563
 air:  60    1294    1291    944    773    636    637    587    560
 air:  40    1164    1160    779    776    678    648    587    561
 air:  20    1123    926    786    826    719    631    900    589
