BMS ECU boards arrived
A project log for DIY Electric Vehicle from Recycled Parts
Converting a car to electric drive using recycled and salvaged EV and hybrid components.
mauswerkzmauswerkz 09/29/2015 at 04:460 Comments
Got my boards from Seeed Studio. They apparently had an issue with my drill file and replaced the slots with pads. That's the OPPOSITE of what I wanted for HV creepage distance. A dremel makes it so that I can at least use the board as a prototype. Assembly has begun. The power supply works and the Teensy LED blinks. Now to populate the other 90% of the components!
