Transmission Mounted
A project log for DIY Electric Vehicle from Recycled Parts
Converting a car to electric drive using recycled and salvaged EV and hybrid components.
mauswerkzmauswerkz 11/16/2015 at 06:090 Comments
The transmission is mounted in the car, fully supported on rubber mounts! I don't have any pictures of it completely mounted, but here's a few snaps of today's progress.
I bought some engine mounts from a Mitsubishi Outlander to support the front of my transmission. They're mounted on either side of the transmission and bolt directly to a plate that bolts to the bellhousing and holds the shaft locking piece.
These pictures were taken before it was all welded together. The welds came out beautifully thanks to my metalworking guru friend. I'll take photos of the finished welded parts and the transmission plate all mounted in next time I work on it (probably Thanksgiving weekend). The driveshaft adapter has been installed and fits very nicely. Everything slides on nice and smooth. A few notes about the transmission
output flange though:
For anyone who wants it, the I've uploaded the DXF file for the transmission adapter here: https://dl.dropboxusercontent.com/u/301235/E46/105 to 96 adapter circle.DXF. This adapts the 96mm bolt-circle flange of the BMW driveshaft to the 105mm bolt-circle flange of the Lexus transmission.
It's designed to use these bushings (http://www.revshift.com/product-p/pfx-frk.htm) and be milled out of 3/4" aluminum.
