Status for May 20
A project log for Improve the Haber process
See if ultrasonic cavitation can be used to fixate atmospheric Nitrogen less expensively than the Haber process.
peter-walshPeter Walsh 05/18/2015 at 22:420 Comments
Summary
1) Power supply design is coming along
2) Final design will require an embedded Arduino Nano
3) Final design will use a laptop (or desktop) as display
Random Status
A lot of little things are happening with the project but nothing of special note, so I won't post this to the feed.
My DigiKey order came in, I'm working up the various device interface software, nothing exceptional.
I'm looking into generating Hydrogen on a small scale, and collecting plumbing for the experimental setup.
I've resolved the safety issue using a lasercut holder for the transducer with rubber feet so it doesn't skitter across the table when energized, and a sculpted-foam parasol to catch the ultrasonic energy. (Which looks vaguely like to the starship enterprise.)
