24 miles later
A project log for Ultimate running aid
Eliminate everything from running but the running part.
lion-mclionheadlion mclionhead 03/19/2018 at 01:000 Comments
For the 1st time, did the 12.8 miles to Walmart with a single battery while it carried chocolate for the mane & supplies for the sandal project.  Previously used 2 batteries & it was  a pain to carry around the store.  This time, it burned 4Ah or 312mAh.  At least without headlights & right after the rebuild, it seemed to get more efficient over time.
Then, it died after a 12 miler.  It did 4 miles at below 8min/mile & carried food back.  The headlights were on.  It burned 4458mAh.  It would be nice to have current usage over time.
Finished Ready Player One & it was pretty much the ending you want.  The author threw no curve balls & wrote around all the mane character's missteps.  It took quite an imagination to come up with the challenges & the visuals in it.  The lion kingdom often thought of hurling Jeff Bezos another $180/year for an Audible subscription, since millenials aren't nearly the audio pirating fiends that generation X was.
