Initial POC
A project log for Raspberry PI Bike Simulation
A web socket example in raspberry pi using socket.io and nodeJS
satya-sankar-sahoosatya sankar sahoo 02/07/2018 at 07:250 Comments
This POC state, I only have created the interrupts check along with the Web socket and Animation.
Second Part:
In next phase, I will update  some parts to the circuit, Like adding pull up , or pull down resistor , Battery , HDMI,
Third Part:
Di playing calories burn or calculating distance travel.
