Finally A break through
A project log for WRONG PROJECT 2
THIS IS DEPRECATED.
MECHANICUSMECHANICUS 12/11/2015 at 09:410 Comments
I need Si not SiO2 for Lithium to bond to in the anode, ball milling with aluminum and then heating to 350 degrees celcius should allow a reduction of silica to silicon.
http://scitation.aip.org/content/aip/journal/jap/80/11/10.1063/1.363669
This paper describes the failure of diodes made with Al SiO2 Si do to high temperature.
