Building the Charging Station
A project log for M.R. E.T. C.E.T.E.R.A #0
Modular Robotic Ecosytem To Clean EveryThing Even(tually) RadioActivity
Dylan James CarrDylan James Carr 03/30/2015 at 08:260 Comments
The first build will be relatively simple. One solar panel and one battery. Only the charging ports to begin with so the robots will not be connected to anything yet as far as data sharing goes.
Electricity is dangerous, grounding is important. Make sure this device is grounded before everything is patched together into a circuit.
Build the Solar circuit-
