Reassembly
A project log for PIC32 Espresso Machine Controller
Using a PIC32 to control brew pressure, steam pressure, and extraction time on a heat exchanger style espresso machine.
sean-ogdenSean Ogden 03/17/2015 at 18:340 Comments
Now that the machine is completely clean, I had to reassemble it. Thankfully, I took a LOT of photos. It's a simple device, but many of the copper pipes look quite similar and are not the same. I forgot to take a photo of the whole thing back together, but here's most of it. I'm going to clean up the case at a later date and probably paint it, but at this time it was -20 degrees F outside, and so paint would likely not dry. So for now I'm just making sure everything works. Surprise, it does work. The steam pressure on this thing is impressive.
