Building a custom DisplayPort -> HDMI cable
A project log for Hydra Multi OS Gaming Console & Controller
This is a game console sized Hydra with a single GPU, running SteamOS, Win7 & Android x86 KitKat. Gameplay & mgmt via modular controller
ericeric 04/07/2015 at 18:470 Comments
Going form this (male) looking at the cable
To this (male) looking at the device
19 pin HDMI type A receptacle connector layout
Using this KEY:
Dual-mode pin mapping
DisplayPort pinsDVI 1.0/HDMI mode
Main Link Lane 0TMDS Channel 2
Main Link Lane 1TMDS Channel 1
Main Link Lane 2TMDS Channel 0
Main Link Lane 3TMDS Clock
AUX CH+DDC Clock
AUX CH-DDC Data
DP_PWRDP_PWR
Hot Plug DetectHot Plug Detect
Config 1Cable Adaptor Detect
Config 2CEC (HDMI only)
I've got the DP cable peeled apart & identified the wires to the pins, with the plastic off it will bend around ( needs to be U shaped) to the HDMI switch and fit in the case. Also found an HDMI cable to sacrifice, & identified the pins. Had to make a needle meter probe for this, & use the USB microscope.
