LED control board designed
A project log for Illuminated (waterproof) Display Matrix
An illuminated sign for use at a festival.
David HopkinsDavid Hopkins 03/25/2015 at 17:570 Comments
fiddled about with Kicad but in the end went back to DesignSpark and got it done in about the same time as it took to make a component in Kicad. sent off to OSH Park (https://oshpark.com/orders/UVd3Zd07) to be made.
models for the MOSFETs are not quite right but the holes are the same which is the important thing
