Kindle Paperwhite 2 (Root Access)
The following shows how to get root access to the kindle pw2 shell by using the serial port (console).
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Because root login is disabled on the serial console as sold by Amazon, some steps are required in order to re-enable root access. For how-to regarding opening the kindle case, refer to the teardown videos on the web. Hardware access to the serial port connector is required for this method. Familiarity with the GNU/Linux boot process (uboot) is also required. Because hardware hacking is required, this method is not considered a 'Jailbreak'. It does yield complete access to the kindle kernel and userland. See full logs and instructions here http://88proof.com/hardware/kindle-20131009.html
