Water Pump
A project log for The Smart Garden
An Arduino IoT Farming Experiment
frank-vigilanteFrank Vigilante 04/08/2015 at 03:260 Comments
The video below shows the first successful run of the water pump. I am using a peristaltic pump from Adafruit. I am using this pump for precision. The pump is 12V DC, which will be the voltage of all the relay powered parts.
