Pumping Station Two
A project log for The Smart Garden
An Arduino IoT Farming Experiment
frank-vigilanteFrank Vigilante 04/17/2015 at 02:032 Comments
When growing tomatoes, the chemical balance of the root zone is very important. Too much nitrogen will hurt yield, too little phosphorus will hurt yield...etc. Liquid fertilizers are sold based on different combinations of nitrogen, phosphate, and potassium. The Smart Garden will be able to deliver specific amounts of nutrients to each plant using the pumps shown below:
The items that are taped on to the pump terminals are flow meters, which will be discussed in detail later.
As noted before, the pumps were found on Adafruit:
https://www.adafruit.com/product/1150
The flow sensors were also found on Adafruit:
https://www.adafruit.com/products/828
Frank Vigilante wrote 04/20/2015 at 10:13 point
Thanks, I've got a few different ideas at this point. My first goal is to hack an analog pH sensor.
Michael Haas wrote 04/17/2015 at 10:15 point
I'm looking forward to seeing the chemical sensors!
