The Printing Continues
A project log for Steampunk Spooler
Steampunk themed 3D printer spool holder with gears, axles, end caps, base, and gear ratio leveraged bearings.
les-hallLes Hall 04/02/2015 at 21:340 Comments
Now printed are all three axles, all six end caps, and two of the six gears (the upper ones on the spool). Have a look at the picots for updates on things like it hs a base now and a photo of the assembled spool. Looking' good! Should have it all printed and assembled in two days.
