Device Holder
This project is a simple add to make charging devices easier.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
It's a small box that hangs off your plug in. It's made for devices with short cords. That way they don't have to hang from the cord.
What makes this item great for improving item experience:
If there's one problem we all come across in our life it’s not having a long enough charger. This project was made to be a cheap way to make it a little simpler. This small box that hangs off your wall plug in. You can place the device in the box so it has a place to rest in. No more hanging devices and no more having to move things around to give it a support. I decided to make this because I have had this problem a lot and thought
Dimensions.
4 inches wide. 5 inches long. 8 inches tall.
