Laser spot size at our hackerspace
A project log for Potpourri
Definition: A mixture of things, especially a musical or literary medley
peter-walshPeter Walsh 04/11/2016 at 18:540 Comments
An image for a post on the HAD blog.
The transparent graticle on my microscope easily shows the spot size of the laser at my hackerspace. I conclude from this that the "kerf" of our laser is about 0.02 inches (20 thou).
Using a micrometer and some precision-ground rods, a 6mm hole measures out as 6.052mm. Considering 0.02 inches as 0.508mm, 90% of the kerf is inside the hole and 10% is outside.
