The Maker Spirit: From Kitchen Table to Micro Startup
A project log for S1-AU Mk1: a 4-bit arithmetic unit
The S1-AU Mk1 is a 4-bit arithmetic unit, designed to help you explore the guts of computing.
ARITH-MATICARITH-MATIC 02/17/2018 at 13:112 Comments
Here's an introduction I wrote to the ARITH-MATIC project: http://arith-matic.com/notebook/the-maker-spirit
ARITH-MATIC wrote 02/17/2018 at 19:38 point
ah! ok - thanks for the tip! ;)
Dave's Dev Lab wrote 02/17/2018 at 19:37 point
it is always good to include a picture with your project logs so that it shows up in the updates stream...
