Swimming platform V3
A project log for EMDrive/satellite
Developing a small fuelless microwave thruster
paul-kocylaPaul Kocyla 02/24/2016 at 07:191 Comment
Started testing the EMDrive V3 on the swimming platform.
Force is clearly beeing detected - I will perform long duration tests to check for directivity and parasitic effects.
Preliminary information will not be posted - updates will come when complete datasets are available. Datasets will be available for download.
Paul Kocyla wrote 02/24/2016 at 17:32 point
I got really clean data in the last test during night hours (11pm to 7am).
Then I tried to make the inverted test (cavity turned 180°) starting at 7:00 am -> Noise amplitude is 5 times as high as in the night, making the second dataset unusable. Tonight I´ll start the inverted test during night again.
