Board V4 ready for flashing
A project log for EMDrive/satellite
Developing a small fuelless microwave thruster
paul-kocylaPaul Kocyla 04/01/2016 at 16:595 Comments
xicor wrote 04/01/2016 at 21:23 point
keep up the good work buddy !, question - is there a formula to determine the shape/dimensions of the cavity based on the frequency of the microwaves ?
Paul Kocyla wrote 04/02/2016 at 05:36 point
Look on emdrive.wiki, there is all information you will need. You will find a spreadsheet made by TheTraveller which checks for various resonant modes.
attiladtoth wrote 04/01/2016 at 17:41 point
That is actually smaller than I though. Imagine if you scale it to the size of the
Rocketdyne F-1.
Paul Kocyla wrote 04/01/2016 at 18:23 point
The inventor claims that a superconductive cavity could hold a car against its gravitational force with only 3kW of power. The cavity does not need to be big. The size depends on the frequency. I don´t know which frequency band works optimal. Most builds use 2.4 GHz as it´s easily available with high power in the form of a microwave oven magnetron.
willemstaal wrote 04/22/2016 at 06:29 point
"Dreaming of cruising the sky with a DeLorean with a fashion model 100 meter above a highway, while making microwave popcorn"
