Test with dielectric - cavity reversed
A project log for EMDrive/satellite
Developing a small fuelless microwave thruster
paul-kocylaPaul Kocyla 04/25/2016 at 06:023 Comments
‪#‎EMDrive‬ test with cavity reversed... this time more noisy, but know what?
It shows reverse direction - I´d say it´s looking good :)
willemstaal wrote 04/25/2016 at 10:18 point
How does  your "reverse" setup look like?
And  is the overall thickness of the dielectric a issue?
Paul Kocyla wrote 04/25/2016 at 12:36 point
Reverse just means that the cavity is turned in the opposite direction.
I just tried the 3mm dielectric, but the thickness probably will be of importance
willemstaal wrote 04/26/2016 at 10:03 point
did you try some glimmer already? you can make this as thick as a sheet of paper..
