I've now added the ability to utilise both the red and green LEDs at the same time, without rewiring as was required previously.
An example patter can be seen here: https://vine.co/v/MeHrzungLTP
A project log for LED Matrix Shield and library
Got fed up of having to look up the datasheet and code examples when using a matrix with an arduino...
