Voltage to frequency conversion circuit
A project log for Open Source Bench Top Power Supply
We start simple: with an open-source variable voltage power supply, which, for now, will use a modified computer PSU.
acpcalinacp.calin 05/09/2015 at 09:250 Comments
The voltage to frequency conversion circuit is the following:
The zener diode has a zener voltage of 10V.
After calculating, the equation which describes the output oscillation frequency with relationship to the voltage Vin applied at the input, assuming Voutmax = 10V,of the circuit is:
\color{White} \large Frequency =  \frac{1}{ R_{c}C} * \frac{1}{ln(\frac{V_{in}^{2} - 20V_{in} - 300}{V_{in}^{2} - 20V_{in}})} For the given values of Rc = 10k ; C = 100n and Vin = 3V, the calculated output frequency is 518 Hz while the simulated one is 521 Hz. Not bad, the errors are probably there because of the output resistance of the op-amp. I thought of a nice method to describe and eliminate that error in the case I don't find the output resistance of the LM358.
