Led Code Used In Example
A project log for Teensy v3.1 - FrSky S.Port & WS28xx Led Shield
Teensy v3.1 - FrSky Smart Port Sensor Shield with addressable led output and telemetry port
charles-lakinsCharles Lakins 05/12/2015 at 17:390 Comments
#include <Adafruit_NeoPixel.h>
#define PIN 2 //pin 2 on teensy shield
#define LEDS 15 //number of leds total
// Based on Adafruit Neopixel example https://github.com/adafruit/Adafruit_NeoPixel
// Parameter 12 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(15, PIN, NEO_RGB + NEO_KHZ800); //NEO_GRB as below colors show
void setup() {
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
int fademax = 10;
int fadeouts[10] = { 0, 0, 0, 0, 0, 1, 4, 16, 64, 255 }; // of number of fasouts
int fadelevels[LEDS] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11}; // of number leds
int scancount = 29;
int scanpos[29] = { 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,13,12,11,10,9,8,7,6,5,4,3,2,1,0 }; // of number of scan positions
void loop() {
  // Some example procedures showing how to display to the pixels:
  for(int i=0; i<scancount; i++) {
    fadelevels[scanpos[i]] = fademax + 1;
    fadeout();
    delay(150); //speed of travel
void fadeout() {
  for (int i=0; i<LEDS; i++) {
    if (fadelevels[i] > 0) fadelevels[i]--;
    int level = fadeouts[fadelevels[i]];
//    uint32_t c = strip.Color(level, 0, level / 2); // GRB Pink OR RGB baby blue
//    uint32_t c = strip.Color(level, level, level); // GRB White OR RGB white
//    uint32_t c = strip.Color(level, 2, level / 4); // GRB green + pink OR RGB blue + red
//    uint32_t c = strip.Color(level, 0, level / 1); // GRB light purple OR RGB med blue
//    uint32_t c = strip.Color(level, 3, level / 255); // GRB green + red OR RGB Red + green
    uint32_t c = strip.Color(level, 0, level / 60); // GRB red OR RGB green
//    uint32_t c = strip.Color(100, 10, level / 3); // RGB all green + Blue fade
//    uint32_t c = strip.Color(1, 10, level / 3); // RGB all RED + blue fade
    strip.setPixelColor(i, c);
  strip.show();
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  if(WheelPos < 85) {
   return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  } else {
   WheelPos -= 170;
   return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
