Material choice
A project log for Team TAHMO
Develop robust and affordable advanced sensing capability for 20,000 weather stations in Africa (lightning, precip water, ...)
nick-van-de-giesenNick van de Giesen 07/28/2015 at 21:271 Comment
With the winning of the business competition in Rwanda, the building of the lightning detector becomes a serious pursuit. We decided on the following selection criteria for the materials, basically based on the idea that we are not professional PCB designers:
- Avoid surface mount (perhaps a next version?)
- Use pre-built modules for the RF components: AS3935 lightning detector and GPS module. There are well designed pcb's on the market that would be hard to beat.
We will build the PCB to house power supply and CPU and allows for solid mounting or connecting the GPS and AS3935 boards. The power supply will be solar panel based. Most of the time, the module will be asleep, during which about 70 muA is used. Once lightning is detected, the AS#(#% will produce an interrupt to wake up the ystem during which the system needs about 50 mA. We assume thunder storms will not last more than 24 hours, in which case the batteries chosen here should work.
With these consideration, these are the materials chosen:
Parts list v0.1 29JUL15
Part# PCBPower supply
IC1Voltage regulator 3.3VLP2950ACZ-3.3/NOPBhttp://www.digikey.com/product-detail/en/LP2950ACZ-3.3%2FNOPB/LP2950ACZ-3.3%2FNOPB-ND/364443
solarSolar panelIXYS SLMD960H12Lhttp://www.digikey.com/product-search/en?KeyWords=SLMD960H12L-ND
D1Zener diodeNZX6V8Dhttp://www.digikey.com/product-detail/en/NZX6V8D,133/568-5917-1-ND/2531204
D2Schottky diode1N5817 STMicroelectronicshttp://www.digikey.com/product-search/en?KeyWords=497-4547-1-ND
batteryBatterieseneloop AA 1800 cycle, Ni-MH Pre-Charged Rechargeable Batteries, 16 Packhttp://www.amazon.com/eneloop-cycle-Pre-Charged-Rechargeable-Batteries/dp/product-description/B005C2Z68M
C1Capacitor 1 muFFK24X7R1H105K TDKhttp://www.digikey.com/product-detail/en/FK24X7R1H105K/445-8517-ND/2815447
C2Capacitor 2.2 muFFK24X7R1C225K TDKhttp://www.digikey.com/product-detail/en/FK24X7R1C225K/445-2859-ND/1008885
solar, batteryScrew terminalOSTVNxxA1x0http://www.digikey.com/product-detail/en/OSTVN02A150/ED10561-ND/1588862
CPU
ATMega328ATMega328ATMEGA328P-PNhttp://www.digikey.com/product-detail/en/ATMEGA328P-PN/ATMEGA328P-PN-ND/2357094
ATMega328IC SocketED281DThttp://www.digikey.com/product-detail/en/ED281DT/ED3050-5-ND/4147600
Y116 MHz crystalHC-49UShttp://www.digikey.com/product-detail/en/ECS-160-20-4X-DU/XC1925-ND/2781930
C3, C4, C522 pF capacitors445-4718-ND http://www.digikey.com/product-detail/en/FK28C0G1H220J/445-4718-ND/2050067
AS3935
Thunder clickThunder click boardThunder Clickhttp://www.mikroe.com/click/thunder/
Thunder clickFemale headers 8-SIP801-yy-yyy-10-001101http://www.digikey.com/product-detail/en/801-87-008-10-001101/1212-1190-ND/3757440
GNSS
GPSModule GPS Ublox NEO-M8TDrotek GPS modulehttp://www.drotek.fr/shop/fr/home/679-module-gps-ublox-neo-m8t-magnetometre-hmc5983-xxl.html
Next step the PCB design.
frankstripod wrote 07/28/2015 at 22:34 point
Congratulations on that win!
