testing day
A project log for Smart Home controllers
Making a Smart Home controller. Stations for each room will a master controller for the home
john-jensenjohn jensen 06/22/2015 at 20:020 Comments
Fired up the computer and tested both the esp8266-01's they work:
wdt reset
load 0x40100000, len 1320, room 16
tail 8
chksum 0xb8
load 0x3ffe8000, len 776, room 0
tail 8
chksum 0xd9
load 0x3ffe8308, len 412, room 0
tail 12
chksum 0xb9
csum 0xb9
2nd boot version : 1.3(b3)
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size : 8Mbit
jump to run user1
sl‚Zÿ
Ai-Thinker Technology Co. Ltd.
ready
AT+GMR
AT version:0.23.0.0(Apr 24 2015 21:11:01)
SDK version:1.0.1
Apr 27 2015 13:55:14
OK
AT+CWMODE=3
OK
AT+CWJAP="removed","removed"
WIFI CONNECTED
WIFI DISCONNECT
+CWJAP:1
FAIL
AT+CWLAP
+CWLAP:(4,"MYSSIDE",-74,"MYMACADDRESS",9)
OK
But as you can see my access point is too far away. Being on the second floor at one end of the house and the router is in the basement on the other side of the house. Go figure. I planned to use a separate wireless router anyways. So its not to big of a set back. Next up get my arduino mini's coded and some code for the esp8266's to be sensor nodes.
