Renamed QFN-28 Boards
A project log for SMT to DIP Breakout Boards
Eagle files used to convert SMT chips to DIP format for use in breadboard prototyping.
kevin-neubauerKevin Neubauer 05/28/2015 at 02:210 Comments
My current QFN-28 boards are designed with 3mm QFN-28 chips. If you have a QFN-28 that is a different size, it will not work with these boards. I have renamed the files to include this info.
