Add-ons : High resolution ADCs
A project log for Python Powered Scientific Instrumentation tool
A multi purpose lab tool accessible by simple Python functions, and capable of studying a wide range of physical phenomena.
jithinJithin 06/14/2015 at 19:100 Comments
Tested the AD7718 24-bit ADC with a custom PCB.
AIN1-AIN4 have been broken out into pin headers directly , and can be used as unipolar inputs/differential pairs.
AIN5-AIN8 will be used to measure bipolar signals. The inputs for these are attenuated and buffered using high precision Op-Amps OPA2277(offset<10uV , drift<0.1uV/C ), and then level shifted.
The StickVise that Hackaday handed out a couple of weeks ago has turned out to be incredibly useful since I use surface mount parts a lot
Fig : Schematic
Now that its functionality has been reasonably tested in terms of software control, and noise spread is below 100uV, an opto-isolated version can be made which should give much better resolution. I hope to post histograms and other characterization results soon.
Unipolar inputs were tested using unbuffered voltages from the 12-bit DAC of the main board.
Differential inputs were checked out using a Peltier plate used a voltage generator.
The main aim of this add-on board for now is to serve as a calibration tool for all the analog inputs on the main board. The AD7718 will first be calibrated against a 6.5 digit standard DMM from Keithley, and then be used as a calibration tool.
The PCB features the REF196 voltage reference, as well as an AD5680 18-bit DAC(as yet untested )
A PCB for a 22-bit ADC MCP3553 is also on its way .
