Some small improvements
A project log for Pan and Tilt Camera steppers and Arduino
100 to 1 geared stepper and extra worm gears to increase torque and reduce speed. Using Arduino
films4youFilms4You 06/02/2015 at 22:190 Comments
Small change to code to swap up joystick to down, (tilt), joystick and visavesta. Not in the supplied code but easy to do with Arduino IDE.
I added a small slide switch on the side the joystick to trigger same a button press to add the slow down movement delay.
Pressing the joystick lever button was too hard to maintain for me for longer times and had poor feedback.
This small small slide switch can be switched on as if the joystick button is being pressed and trigger the extra delay in the code causing slower pan and tilt movements.
